Substructure finite element analysis codes
I want to develop a simple finite element analysis codes using the substructure method.
Could any one give me some links or references, especially if some simple source codes will be grealy appreciated.
thanks,
RE: Substructure finite element analysis codes
thanks, feajob.
Do you know by any chance where i can find some demon source codes for substructure analysis
thanks
No, I am not sure about the source codes. Based on the theory, I think that the substructure analysis is nothing else than manipulating the local-global stiffness matrixes. For sure, having the source code can save your time. Look at the educational open source FEA codes. Because, I don’t think any commercial FE code give you this source.
Good luck,
AAY
