Catia v4 to UG Dwgs +want to change dwgs
I have some UG dwg files which are translated from
catia V4.
I wanted to modify dimension & tolerance in dwgs but it didn't allow me to do so.
Also tell me if any other possible way,
early response would be a great help.
Thank you,
RE: Catia v4 to UG Dwgs +want to change dwgs
It's possible that the translation caused the dimension to become a non-living dimension.  Do an Information -> Object to find out if it's still being recognized as a dimension.  If that's the case, the only alternative is to re-dimension the drawing.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
