Layer category
Layer category
Is there an easy way to create layer category names corresponds to the numbers.I would like to standardize the names before I start working a new part.?
For example: Solid Parts- 1 to 10,Inter Parts- 11 to 20, Sketch- 21 to 30 etc...
RE: Layer category
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Layer category
RE: Layer category
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: Layer category
When I get to determine layer structure I usually group all related entities that make up a certain feature set on a layer. For instance, if I want to add a 'widget' feature, I'll put all the geometry, the extrusion (or revolve, whatever), and any necessary trim sheets on layer 'widget'. That way when I want to edit feature widget I just turn on that layer and all the necessary geometry is there.
Is it just a standards thing or does it make the file easier to edit later? If it will make life easier I'm all for it, please educate me.
RE: Layer category
I have a nasty habit of assigning catagories after I have completed the part if they are not pre-assigned, so using a seed part goes a long way in helping me overcome this self-discipline problem.
RE: Layer category
It all depends on how well the categories are set up to begin with. I suppose there could actually be overkill when using categories (one sketch/layer or one set of curves/layer). I think it's just what makes sense for the product that is being designed in UG. I believe GM has a fairly decent category set up:
Solids on layer 1
Wireframe on layer 2
Centerlines on layer 3
Theoretical on layer 4
Sections on layer 5
Developmental on layer 6
Mate on layer 7
Any number of user-defined categories may exist as long as they follow a naming convention set by GM. Sometimes a user may just want to look at the geometry that was used to create the part. The user would make layer 6 visible & from there all curves, sketches & sheets or solids used to define the part are there.
I personally feel that whatever category method users are more comfortable with is the best method, rather than giving an example & claiming it to be best. I used to seperate everything on a layer of its own (like sketches) & make a category for it....but once I got used to GM's method, it really wasn't much different. However, things can become jumbled from time to time. It all depends on the complexity of the part.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
