Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
heavenly (Aerospace)
10 Jan 05 5:33
hi,
torque= ang.accleration X moment of innertia
  (Nm )       =deg/sec.sq   X  Nm2
  but from above conversion,how to reach to get Nm
 & also if we convert deg/sec.sq into rad/sec.sq,
 value will be reduced by 57 times
   MY QUESTION HOW TO GET .....Nm
thanx in before
John
Helpful Member!(2)  FredGarvin (Mechanical)
10 Jan 05 8:13
Your units are not correct.
The units for polar moment of inertia are: kg*m^2
The units for angular accel. are: rad/sec^2
radians are not a true engineering unit so they do not enter into cancelling out. That leaves you with:
(kg*m^2)/sec^2 = N*m
10 Jan 05 23:21
Hi Fredgravin
 HEARTLY THANKFUL TO YOU FOR GIVING THIS VALUABLE
INFORMATION
with warm regards
John
edbgtr (Aerospace)
11 Jan 05 2:37
FredGarvin
The radian is an engineering unit. Degrees are not.
The radian measure of an angle is defined as the arclength divided by the radius of the arc. It is thus dimensionless, and hence disappears when dimensional analysis is performed to determine the resulting units of a formula.
Take care.
Ed.
Close Box
Join Eng-Tips® Today!
Join Us             Close
