EMBEDDING MS EXCELL WRKSHT INTO ACAD
I HAVE FOUR PAGES IN SHEET 1 OF THE ABOVE REFERENCED SPREADSHEET THAT I AM TRANSFERRING INTO 2004 ACAD VIA OLE OBJECTS.  ONLY ONE AND ONE HALF PAGE IS BEING TRANSFERRED.  HOW CAN I TRANSFER ALL FOUR PAGES OF SHEET ONE INTO MY ACAD FILE.
RE: EMBEDDING MS EXCELL WRKSHT INTO ACAD
As far as I know, you can't.  There is a bit-limit to OLEs.  You have to insert two separate OLEs or reduce the file size, by making the .xls smaller.
tHE ONLY SOLUTIOIN IS TO COPY AND PASTE THE DATA IN SECTIONS.  WHEN YOU PASTE IT SET THE TEXT TO THE SAME SIZE AND THEN SIMPLY LINE UP THE LINES OF YOUR CHARTS.
THE MAJOR DRAWBACK IS THAT AutoCAD WILL THEM AS SEPERATE ENTITIES AND WHATEVER YOU EDIT IN ONE WILL NOT SHOW IN THE OTHER.:-(
Use AcadExcel, I try it and found that is easier that any other method.
Look on http://www.lyrasoft.net/
