Tyre spring rate
Tyre spring rate
Could anybody help me out with a simple test method to find the Tyre Spring Rate or a Constant figure to use in suspension programs for the Tyre Spring Rate in Kg/cm or lb/in.
RE: Tyre spring rate
should be around 250 N/mm
Cheers
Greg Locock
