Axel Diameter?
Axel Diameter?
Axel Diameter?
How does one go about calculating what the best diameter axel would be for a givin application? An axel too small with bend and de-shape but an axel to big will have too much rotational inertia?
Brendan
RE: Axel Diameter?
What else do you want to know?  You've listed some of the factors to consider.  Make a decision based on engineering judgement.
RE: Axel Diameter?
I think in most cases, the rotational inertia would not be a major factor.
You might also consider vibration of the shaft, whirring motion, fatigue, how it is to be attached, cost and drag of bearings, etc.
RE: Axel Diameter?
YOu would also want to give careful consideration to any shock loading the axle would expect to see.
rmw
RE: Axel Diameter?
And unsupported length.
RE: Axel Diameter?
If you think inertia is going to be problem you should include tubular shafts in your quest.
RE: Axel Diameter?
The ASME and Westinghouse shaft codes are often used to determine what diameter is required to keep stresses below a specified level, with a particular factor of safety. These codes can be found in many engineering text books. In some applications, torsional and bending deflections will also be an important consideration.
