Steel Building
Steel Building
Does anyone has information about steel (corrugated metal or similar materials) building for a proposed auto repair facility. The owner wants to go for metal structure since it is cheaper, at least he thinks so. However, the city requires any steel building to have non-steel appearnce (i.e, conceal with stucco or other panels). Also, What would be the construction cost per sft as compared to masonry or wood frame building? The plan is to add a 2000 sft auto repair facility with the existing steel (metal) building? Thanks in advance.
RE: Steel Building
If your located in the USA. Take a look at this site.
www.butlermfg.com/
pennpoint
RE: Steel Building
RE: Steel Building
http://usabldg.com/auto.html
The home page is www.usabldg.com
Pricing is going to vary greatly depending on location, spans, type of cladding, construction conditions, etc.
You may want to get some quotes to develop your budget numbers.
