Cutting Splines
Cutting Splines
Question: I need to have a shaft manufactured for an automotive gearbox application. The shaft has a variety of diameters and bearing surfaces plus 3 splined sections. What is the best and most economical approach? Having the shaft CNC manaufactured via CAD, or manually machining the component in a lathe. What machine is used to cut splines, internal and external?
Many thanks in advance,
RE: Cutting Splines
http://www.slatertools.com/
RE: Cutting Splines
http://www.kinefac.com/index.htm
RE: Cutting Splines
The cheapest way I have heard of is spline broaching.
tell us how u finally did it.
RE: Cutting Splines
Robert Setree
www.advanced-grinding.com
