Library Features
Library Features
Library Features
I think I have discovered a limitation of Library features.  I have made two features that are the same except for one difference.  One feature is made with (2) extrude cuts and one feature is made with (1) extrude cut by selecting various closed contours in a sketch.  The feature made with multiple extrude cuts works fine.  The feature made with the contour selected extrude cut fails.
I'm not sure if this is a limitation or a bug but in either case I think Library Features should support the contour selection extrude.  Does anyone have any information onthis?
SW2005 SP 1.0 EV  WIN XP SP1
