DWG Editor Help Files
When I'm in the DWG Editor and I try and acess the help files I recieve an error.  What do I need to do to get this working?
RE: DWG Editor Help Files
"Unable to find the requested file.  dwgeditor.chm"
I click the "help" tab, get the pull down and when I click "DWGeditor help"  I have the error.
Make sure you have the file in this location - C:\Program Files\SolidWorks\dwgeditor\English\help - If you do try running a repair on your SW. See FAQ559-908
If you don't have that file try running a Modify - Same as a repair except you have to pick Modify instead, plus you have to have the CD's at your station.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
