Turn a modem into serial port? use a modem as serial port?
I am developing a product which communicates through an installation terminal program running at a notebook computer. The product uses its UART / serial port to communicate, the problem is that nowadays most notebooks don't have serial port. My question is that, I know most notebooks now have built-in internal modems, can I turn that modem into a serial port? or can I use it as a serial port? Thanks guys.
Jinghong
Jinghong
RE: Turn a modem into serial port? use a modem as serial port?
TTFN
what level are you working at? are you developing the product or selling it?
a little more info would be helpful in order to be helpful...
regards
killa
Andy
Killa: I am not trying to send data through modem. I need to send data through a serial port, I want to turn PC's modem port into a serial port just like other serial ports that a PC may have. We are developing products, and our products need to get information from PC through a serial port connection. I think Andy might be right and I cannot bypass the modem and use the serial port without hardware change.
But for a while I do hope that there will be some softare/firmware code that I can apply to the modem to disable its modem specific functions and feed the data it gets from the serial port right through to its RJ11 port.
Therefore, there would never be a means of connect the serial UART output to the modem output under normal circumstances.
TTFN
regards, -john-
