Ss & S1 USGS 2002 Long & Lat values
Does IBC allow for structural engineer to use Ss and S1 from the USGS 2002 data instead of 1996?
Thanks in advance.
RE: Ss & S1 USGS 2002 Long & Lat values
I don't think there's anything in the IBC that says you can or can't use the newer maps.  There are some situations where using a newer code can cause coordination problems.  But in this case, the newer maps simply reflect new research, not a new design methodology.  All of the government projects that I work on require the use of IBC 2000 with the 2002 USGS maps.  So unless your code authority doesn't allow use of the 2002 maps, there shouldn't be a problem.
You may run into trouble with your permitting department if the values used are less than what they normally see. I know I would.
