Using the HIDE command
Hi all,
I'm laying out shop drawings for fabrication of some piping, using the HIDE command to get rid of the unwanted lines. Is there a way to pan and zoom while keeping the vports in the HIDE view? Evertime i have to do something in paperspace, i have to go into all the viewports, and redo the HIDE command. Thanks in advance!
RE: Using the HIDE command
These set the view, so you can pan, zoom, etc, and still have a hidden or shaded drawing. You should be able to set this in each viewport as well. Warning though, it will decrease the performance of Autocad when you work in a hidden or shaded view.
