Combo Box Value
Combo Box Value
I have several combo boxes I am using. The data for all boxes is supplied from a table using the “ListFillRange” on the Properties section. The table contains values that range from 10% to 100%. When I click on the combo box, the values are displayed as percentages. However, when I choose the value I am interested in it shows in the box as a decimal. In addition, I have cells that are linked to the combo box which also show it as a decimal rather that a percentage. All cells are set to percentage.
How can I get the combo box and cells to show the number as a percentage rather than a decimal. As a minimum, I would like the combo box to show the value as a percentage rather than a decimal. The linked cell doesn’t really mater since it is used for calculations only and does not appear to the user.
RE: Combo Box Value
If you need a working example I should find the codes.
m777182
