Establishing Material Model
Hello All,
I am looking for a way to establish a material model that can be used for FEA with limited experimentation capacity at hand.
The product is very interesting " A Baked Cookie". I am using Pro/Mechanica which asks for following material properties:
1. Young's Modulus
2. Density
3. Poisson's Ratio
4. Ultimate Tensile Strength
5. Ultimate Compressive Strength
4 & 5 required to take care of Brittleness of the cookie
Is there any way to get around with porosity?
Any help much appreciated,
Yugendra
1. Young's Modulus
2. Density
3. Poisson's Ratio
Yugendra
RE: Establishing Material Model
However, it might be possible to approximate overall average behaviour with a sort of "lumped-parameter" model eg if the average cookie region has 5% porosity then reduce the stiffness, density and strength by this amount.
You could also try this for different likelihoods of porosity (eg 95% of the cookie might be only 5% porous but the remaining 5% of the cookie could be 20% porous?!).
As with lots of problems, the answer is probably a sensitivity study on the effect of these approximations.
I've tried something similar as a crude approximation for
casting defects in grey iron...
Good luck,
MToft
