drawing property line from a deed
hey all!
im try1ng to learn some surveying skills and i have a little problem...i would l1ke to know how to enter northing and easting info into autocad. which command should i use to do this?
regards
jack
regards
jack
RE: drawing property line from a deed
Either way, Format Length and Angle Units as you want to work. I work in decimal Length and dms Angles, as that relates to deed plots easiest. Then pick your starting point. Then:
Cart.: @2,3 goes +2' in X and +3' in Y.
Polar: @2<2d15'30" goes +2 at the bearing described.
Is this new to 2005?
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
I like using the @ as LHA stated above.
