Contact model for pipeline and seabed
Ansys has three contact capabilities: node to node, node to surface and surface to surface. if i want to model line-to-surface, which one i should use? In the contact wizard, there is option of line to surface. So it belones to surface to surface?
I model a pipeline contacts with seabed. In contact wizard, i pick the line for pipeline and surface for seabed to build the line-surface contact pair. but the result is funny, seems no contact occour at all. I suspect whether it is correct to model this phenomenon, or i make some other wrong for contact parameters.
Any suggestion welcome. thanks.
RE: Contact model for pipeline and seabed
Cheers,
-- drej --
U can even apply diffrent wave theories usign this element
all the best#
cheers
femfriend
