Converting 3D to 2D (again....)
As if this hasn't been hashed enough... I have a 3D plant layout for one of "the big three". It shows columns and machines and such in 3D utilizing Factory Cad, Arch Desktop and who knows what other evil things. What I would like to do is get simple 2D drawings (Front, Top and Right side views would be great) from this 3D file. I read an earlier post of a similar topic that suggesed WMF format. I tried that, and frankly it worked amazingly well, except the scale is all wrong. Is there a way I can get the WMF procedure to work and maintain the proper scaling, or perhaps another procedure that will produce the desired results? Thanks in advance.
RE: Converting 3D to 2D (again....)
That would be the easiest way.
Everything ends up on the same layer, but it is 1:1
and correcting the layers usually isn't that bad.
what about the "flatten" command from ExpressTools V1-9?
Lothar
ADT 2004
ACAD 2002
I have some detailed posts on this very subject, but you'll have to search this site for them as the most recent I think is about 2-3 wks ago.
Good Luck!
C. Fee
I think since Autocad 2004 the best way to do this, is a dwf file. All other methods need a lot of time. Look to Autocad website.
good luck
f.schuepany
