Sketch entities in drawings
Feel I may have toggled something on or off in either document properties or system options.
Experimenting with some drawing settings yesterday. Now I am no longer able to snap a line to the mid point of a part in a drawing. If this is any help a dialog box pops up which reads,
Please select entities from the same drawing view
Thanks in advance for your help.
RE: Sketch entities in drawings
Click on the following:
Tools
Options
Document Properties
Grid/Snap
Snap
Here you can make sure you have the options check-marked that you need.
Hope this is what you were looking for.
It sounds like your sketched line is not associated with the view the part is in.
Right-click the view and "Lock view focus".  Then draw your sketch and you should be able to tie it to the part.
Both options worked.
Thank You
