Taking the natural log of a negative number is Excel.
Is there a way to calculate the natural log of a negative number (It should yield two solutions) in Excel without getting an error message. Your help is greatly appreciated.
pmans
pmans
RE: Taking the natural log of a negative number is Excel.
The IMLN(number) function works, but yields a "text" cell. Do you know how to change this into a "number" cell, so it can be used as part of an equation somewhere else in the spreadsheet.
Thanks in advance,
pmans
Doing complex math with the analysis toolpack is a pain in the a**. If you do a lot, get something like MathCAD.
Here is a follow-up question, related to the imaginary part of the solution. I've noticed that the imaginary part of the natural log of any negative number is 3.14..i or PIi. Do you guys know why that is? What's the significance of PI in the imaginary part of the solution?
Thanks in advance,
pmans
e^(i*Pi) = -1
from which it follows that
log(-1) = i*Pi
Then from basic (non-complex) maths we have
log[(-1)*(x)] = log(-1) + log(x)
QED
bml and jgrhist - it sounds like you are saying the only thing we can do with a complex result is parse it into real/imaginary and go from there - if so I disagree. excel has complex functions which work directly on complex numbers as posted from help below.
I apologize in advance if I have misunderstood your comments.
IMABS Returns the absolute value (modulus) of a complex number
IMAGINARY Returns the imaginary coefficient of a complex number
IMARGUMENT Returns the argument theta, an angle expressed in radians
IMCONJUGATE Returns the complex conjugate of a complex number
IMCOS Returns the cosine of a complex number
IMDIV Returns the quotient of two complex numbers
IMEXP Returns the exponential of a complex number
IMLN Returns the natural logarithm of a complex number
IMLOG10 Returns the base-10 logarithm of a complex number
IMLOG2 Returns the base-2 logarithm of a complex number
IMPOWER Returns a complex number raised to an integer power
IMPRODUCT Returns the product of two complex numbers
IMREAL Returns the real coefficient of a complex number
IMSIN Returns the sine of a complex number
IMSQRT Returns the square root of a complex number
IMSUB Returns the difference of two complex numbers
IMSUM Returns the sum of complex numbers
IMREAL(IMLN(-15))=2.70805020110221
IMAGINARY(IMLN(-15))=3.14159265358979
