pid three position output algorithm
I need a algorithm for a three position output with simulated feedback
RE: pid three position output algorithm
What do you mean by "three position output with simulated feedback?"
xnuke
Is this a homework problem?
TTFN
If it is not a homework problem, I think the Electric Motor Controls forum is not necessarilly the right place to ask. I would try the PLC or Control Systems forums, those folks deal with the propeller-head stuff more than we do.
If it is a homework problem, get a life and buck-up like the rest of us did.
"Venditori de oleum-vipera non vigere excordis populi"
I can't give you an algorithm but the idea is
Output above setpoint-drive full negative
Output within a band around setpoint-do nothing
Output below  setpoint-drive full positive.
A real world example-heating and air conditioning control.
Temperature about correct-no heat or air.
Temp too high-turn on the air.
Temp too low-turn on the heat.
