Anyone have defualt menu
I just downloaded the trial autocad 2005.
There are no menus included, and I need
to start learning this software asap. Is
there a default menu list that can be downloaded
so I can go through the tutorials and start
the motor going ?
RE: Anyone have defualt menu
There should be menus included in AutoCAD. If you do not see them, then try changing your Profile (Tools>>Options>>Profiles) or if that does not work, then load the menu from the AutoCAD folder. It should be name ???.mnu
"Everybody is ignorant, only on different subjects." — Will Rogers
