API to Set Dual Units
I know how to toggle Dual Disply of units on and off, but I can't figure out how to set the dual units (i.e. inch/mm, precision, tolerance)
Ken
RE: API to Set Dual Units
Go to tools, options, document properties, dimensions, precision. It's in there.
ModelDoc2::SetUserPreferenceIntegerValues
Set values for:
swDetailingLinearDimPrecision - Integer value for precision.
swDetailingLinearTolPrecision - Integer value for precision.
swDetailingAltLinearDimPrecision - Integer value for precision.
swDetailingAltLinearTolPrecision - Integer value for precision.
swDetailingAngularDimPrecision - Integer value for precision.
swDetailingAngularTolPrecision - Integer value for precision.
"Customer satisfaction, while theoretically possible, is neither guaranteed nor statistically likely.--E.L. Kersten
http://www.EsoxRepublic.com
TheTick,
Here's a snip of the code I am using, but it doesn't seem to be working:
CODE
If (Part.GetUserPreferenceIntegerValue(swUnitsLinear) = swINCHES) Then
  'Set to Metric
  Part.SetUserPreferenceIntegerValue swUnitsLinear, swMM
  Part.SetUserPreferenceToggle swDetailingDualDimensions, True
  Part.SetUserPreferenceIntegerValue swDetailingLinearDimPrecision, 2
  Part.SetUserPreferenceIntegerValue swDetailingLinearTolPrecision, 2
  Part.SetUserPreferenceIntegerValue swDetailingAltLinearDimPrecision, 3
  Part.SetUserPreferenceIntegerValue swDetailingAltLinearTolPrecision, 3
  swApp.SendMsgToUser "Conversion to Metric made successfully"
Else
  'Set to Inch
  Part.SetUserPreferenceIntegerValue swUnitsLinear, swINCHES
  Part.SetUserPreferenceToggle swDetailingDualDimensions, False
  Part.SetUserPreferenceIntegerValue swDetailingLinearDimPrecision, 3
  Part.SetUserPreferenceIntegerValue swDetailingLinearTolPrecision, 3
  Part.SetUserPreferenceIntegerValue swDetailingAltLinearDimPrecision, 2
  Part.SetUserPreferenceIntegerValue swDetailingAltLinearTolPrecision, 2
  swApp.SendMsgToUser "Conversion to Imperial made successfully"
End If
None of the "alt" values change. Am I missing something?
Ken
Where's the clue I missed? Ah yes, the subject line. That's both feet in my mouth today, so I'd better sit down.
What version are you using?  At one point there was a bug in which the precision of the dual units did not update when the value was changed through the options dialog.  I think the primary dimension precision value was being used for both the primary units and the dual units.  This was fixed in SWX2004 SP4, but it would prevent even properly written code from updating the drawing.  If you are using a previous version update your service pack and then recheck the results.
Currently running SW2004 sp5.0
Ken
