view represent simplify in Pro/E wildfire?
I need to remove machined holes from a flat pattern so I can create a DXF for laser cutting. In previous Pro/E versions I used view, represent, simplify. Menu mapper doesn't map this function, does anyone know how to do this with Pro/E Wildfire?
RE: view represent simplify in Pro/E wildfire?
Joe Borg
www.methode-eur.com
HTH
Brian
Thankyou both very much.
You are right about the view not being parametric any more. You can do a "save as" on the drawing and keep it for records, besides you can delete the model from the drawing to end up with just a draft stable proe drawing. After all a .dxf is not in any way associated. I suggest that you do not save the original drawing with snapshot views.
Joe Borg
www.methode-eur.com
Another option is to use View-->Drawing Display-->Edge Display and use "Erase line" to get rid of what you don't want.
Hope it helps
Mark
Mark
