Blower vs compressor
At what point do you go from a blower to a small recip or centrifugal compressor in terms of compression ratio and flowrate, economically - capital and operational.
RE: Blower vs compressor
The choice between dry screws, flooded screws, centrifugal, or recip is pretty complex and if you need discharge pressures much above 30 psig then you really need to provide more information on your application before anyone can give you competent advice.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
Trevor
Lots of variables in this stuff.
David Simpson, PE
