solidification of leachates and strength of material
Does anyone know of any research or information on the correlation between solidification of contaminated soil and the strength of the soil using quick undrained triaxials, ucs, FWD, cone penetration, NAT tests, CBR, plate bearing, clegg hammer etc
RE: solidification of leachates and strength of material
The issue here would be to determine the extent of contamination, and recommend the safe disposal of the contaminated soil.
This sound similar to a project where we stabilized some contaminated steam sludge (hazardous) so that we could place it in a RCRA lined landfill. I've also done some paper mill sludge, residual soft soil road base and hazardous waste stabilization. I've used several additives (kiln slag, portland cement, fly ash and lime). As with most cases, cost and the proper additive is generally determined be the availability of the additive.
Point to note!!! In almost all of my applications, we were only trying to achieve minimal soil properties so that the material could be handled and/or self-supporting. If you are trying to achieve usable geotechnical properties, you are probably not choosing the most cost effective solution (ie. soil/sludge stabilization is expensive).
Respond if you care for more information.
Good luck, these projects tend to be messy.
