Roughness values
Roughness values
Roughness values
I'm looking for a table on roughness values for various materials.  Specifically plastic.  Thank you.
RE: Roughness values
Most plastics I've dealt with have been modelled as "smooth" with good success.
Good luck,
Latexman
For typical pipe materials (PVC, etc), use absolute roughness ("ks") = 0.003 mm (as compared to about 0.0015 mm for copper, 0.046 mm for new black steel pipe).
Brian
Thanks.  I was using 0.00005 ft (.0015 mm).
My figures are from the CIBSE guide (as used for pipe sizing for building services in the UK; equivalent to ASHRAE).
Brian
