Why is Catia V5R13 Shutting down Automatically???
When I start Catia V5R13, it will run for about 30 Minutes and then shut down without notice. I've tried to find something under the Tools/Options to disable this. But I have been unsuccessful so far. Any info or direction would be greatly appreciated...
RE: Why is Catia V5R13 Shutting down Automatically???
Is the supported video driver installed.
Don't know if this your problem or not.
forfun
Sometimes bad crack close CATIA after 30 minutes...
Eric N.
Do you have a good connection to the licence server (I don't think this would happen with a node-lock licence)? If not, CATIA will shut down after it hasn't had the licence for the time specified in options.
If you lose connection with the licence server, CATIA pops up some warning about "cannot get licence from server, will stop after 5 unsuccessfull attempt"
but the 30 minutes sounds like a bad crack ;)
Eric N.
