.sldbomtbt Question
.sldbomtbt Question
First off im sorta new to solidwork, so bear with me.
I've seen that i can save my bom as a template. But i want to edit my standard BOM-standard.sldbomtbt
How can this be done? I would like the Part number column to be linked to the properties Part no. instead of the actual file name as it is right now. The Description column in this specific BOM template reads the properties but the Part number column does not.
Help would be appreciated
Thanks in Advance!!
Thanks in Advance!!
Adam
RE: .sldbomtbt Question
you may want to control properties at the sheet format level. (.slddrt) cruise help using keywords like sheet format.
dsgnr1
Experience is a dear teacher, and only fools will learn from no other.
Ben Franklin
I see your point now.
dsgnr1
search help with keywords bill of material-custom properties.
Part number column could be added easily, but I don't know if you can remove item number.
dsgnr1
Thanks Again, i'll continue my search for a solution.
Adam
-insert a BOM on a new drawing, doesn't matter what
-select the "Part Number Column", the properties of that column should appear to the left of the view window
-there should be a few options displayed in the "Column Properties" area - Item Number, Part Number, and User Defined. Choose user defined
-from the "Custom Property" menu, choose the property you want this column to be linked to
-change the title if needed
I have 2004, I don't think this has changed much in 2005.
Eng-Tips:-
Intelligent Work Forums For Engineering Professionals
Adam
