Structural Steel Dimensions?
I am looking for all feature dimensions for steel structural c channel. Looking in the Ryerson book only shows overall dimensions. I am looking for radius and taper dimensions. I know these are not held that closely but I would like to be in the ballpark.
RE: Structural Steel Dimensions?
The problem with the radius is that it apparently varies from one mill to the next- that's why they don't tabulate it. I normally come up with a radius based on the "k" values in AISC-ASD (for pictorial use). Note also that there is a radius on the tips of the channel webs which isn't tabulated anywhere. The "k" value is probably based on the largest common radius, while the tabulated section properties are probably based on the smallest common radius.
