Non Contact Speed & Length Measurement
Can anyone help with this. Looking for a sensor that will suit
RE: Non Contact Speed & Length Measurement
I'm sure people can help, but most of us aren't telepathic and you haven't told us anything about the objects or material you want to measure, what accuracy you require, what sensing range, what output, how fast, etc.
Put a bit more information about your application in your next post and I'm sure you'll get a good response.
If we learn from our mistakes,
I'm getting a great education!
Scotty Thanks for you reply.
I am trying to measure product that is in a tube form
Speed range 0 - 400 ft/min
Sensing range 100 mm
Accuracy +/- 0.05%
Hopefully you can help
Hi Kenny,
This is quite fast for a contactless measurement at that accuracy class. I'll post some more questions:
What is the surface finish of the product?
Does the product have any surface markings, or can such markings be added?
Is non-contact vital?
Where does the product finish up? Presumably it eventually is coiled or similar?
I can imagine some parallels with the printing industry, and maybe some transferrable technology, but that is just in my mind's eye. I am probably miles wide of the mark! The more gaps you can fill in about the product and the process, the easier it is for us to visualise your problem.
and what is the rate at which the product comes?
TTFN
Kenny:
the 0 ft/min will be difficult to measure with .05% accuracy (+/- 0 ???? )
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
