RTW compilation error: parser stack overflow; code too complex
I'm running into an issue with RTW using the generic real-time target.  The problem is that the compilion step errors with a parser stack overflow; code is too complex error.  I haven't found any useful info on the Mathworks site or on Microsoft's site about resolving this error.  I'm using Visual Studio 6 as the compiler.
The full error is as follows:
### Compiling test_model.c
cl -Ot   -DUSE_RTMODEL -DMODEL=test_model -DRT -DNUMST=2  -DTID01EQ=1 -DNCSTATES=27  -DMT=0 -DHAVESTDIO   -c -W3 -DCRTAPI1=_cdecl -DCRTAPI2=_cdecl -nologo -D_X86_=1 -D_WINNT -D_WIN32_WINNT=0x0400 -D_WIN32_IE=0x0300 -DWINVER=0x0400 -DWIN32  -D_WIN32 test_model.c
test_model.c
test_model.c(6925) : fatal error C1026: parser stack overflow, program too complex
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
Has anyone seen this error before and perhaps found a workaround?
M. Monroe
