protective coating for steel pipe
what is the suitable protective coating for external steel pipe with 95 celcius degree service temperature?
where i can find list of organic coating properties (ex. temperature resistance value of each coating material)?
thx for your advice
thx for your advice
RE: protective coating for steel pipe
http://www.international-pc.com/pc/
for example.
Experience has dictated that, in general, the manufacturer's data really needs to be verified by appropriate performance testing which will take us down a different thread.
If you are insulating the pipe, review NACE RP 0198 to get guidance on the paint systems to be used. You can also get guidance from the eight parts of ISO 12944.
For your information, our company has tested and qualified the following system for atmospheric exposure in an arid environment:
1. Polyamide epoxy primer 50 microns
2. Polyamide epoxy hi build intermediate 100 microns
3 Aliphatic polyurethane topcoat 50 microns
Total DFT: 200 microns.
Thermal spray aluminium could also be an option for you.
Take a look at NORSOK M-501
http://
Good luck
Steve
Steve Jones
Shell Iran Offshore Ltd, Dubai
Open the Coatings file and look for the KEMA 300PA epoxy data sheet.
This company produces a great product that will give you the results you are looking for.
gibson55
surface prepartion of SA2.5
1-Inorganic zinc silicate primer 50 micron
2-Tie Coat polyamid epoxy 50 micron
3- Top Coat 50 micron ( Depend on the required Weather/External environment)
The Two coats 2 & 3 can be replaced with a surface tolerant coating such as Amerlock 400.
Yuo have to be also carful about the application of the coating at that high temperature. You need to have a flexible system that can be applied at a surface. Most epoxies at this tempurature will dry very fast.
Yuo can also check Amercoat 878 HS
htt
Also consider PSX 700
If done to a live line at 95C then the reactive resins contained within their (vankami & SJones) recommended formulations will very quickly breakdown and create severe pinholing and potential charring of the wet film causing it to be unusable.
If however the application is to be done to a shut-in line then either one of the three recommended coating systems may be appropriate.
The novolac- based epoxy coating, being 100% solid in nature, is the only one that can offer a one coat application.
gibson55
All have an IOZ primer, with some kind of tie coat, finished off with some kind of tough topcoat like a polyurethane.
If there's no industrial chemical splash/fume contamination, a two coat system would suffice.
By the way, thermally sprayed aluminium for coating new insulated lines is now becoming best practice to avoid CUI.
Cheers
Rob
Thank you
