steel pipe manufacturer
Hello:
Can anyone suggest where reputable /well known steel pipe (API 5L, 5LX, 5LC & 5LD spec's) manufacturer?
Thanks in advance
RE: steel pipe manufacturer
look for TENARIS
You may also want to check with API - I believe they have a member listing which should include tube/pipe manufacturers.
You have a choice between seamless tube producers and welded tube producers.....based on your requirements.  High quality seamless tube producers include Tenaris and Sumitomo while welded producers include Maverick Tube and Lone Star Steel, among others.  See the following for the composite list...
http://api-ec.api.org/multimedia/industry/composite.cfm
