Permissible Noise Exposures
Safety guys:
I know OSHA has that section/chart where "hours per day" exposure correlates to "sound level in dB" beginning at 90 and going up to 115 with a corresponding 8 hrs declining to 0.25 hrs of permissible exposure.
My question is:
I seem to recall a magic number like 85 db that you don't want to exceed with noise-generating equipment. This could have been a specific company's policy (e.g., Chrysler) and perhaps by not exceeding this number and knowing that a normal shift is 8 hrs, you wouldn't have a "hearing protection required" issue. Is this true or is it some other number? 80 or 90?
My question is:
RE: Permissible Noise Exposures
John
(c) Hearing conservation program. (1) The employer shall administer a continuing, effective hearing conservation program, as described in paragraphs (c) through (o) of this section, whenever employee noise exposures equal or exceed an 8-hour time-weighted average sound level (TWA) of 85 decibels measured on the A scale (slow response) or, equivalently, a dose of fifty percent.
For purposes of the hearing conservation program, employee noise exposures shall be computed in accordance with appendix A and Table G–16a, and without regard to any attenuation provided by the use of personal protective equipment.
(2) For purposes of paragraphs (c) through (n) of this section, an 8-hour time-weighted average of 85 decibels or a dose of fifty percent shall also be referred to as the action level.
(d) Monitoring. (1) When information indicates that any employee’s exposure may equal or exceed an 8-hour time weighted average of 85 decibels, the employer shall develop and implement a monitoring program.
h
John
The employer shall administer a continuing, effective hearing conservation program, as described in paragraphs (c) through (o) of this section, whenever employee noise exposures equal or exceed an 8-hour time-weighted average sound level (TWA) of 85 decibels measured on the A scale (slow response) or, equivalently, a dose of fifty percent. For purposes of the hearing conservation program, employee noise exposures shall be computed in accordance with appendix A and Table G-16a, and without regard to any attenuation provided by the use of personal protective equipment.
http:
