Performance expectations from laser cutting phenolics
Greetings group,
I am new to the fabrication/manufacturing end of engineering, so I would like a little help to determine whether the quality of cut I am getting from a laser cutter is in line with the rest of the world.
I have recently begun some prototype testing for a product that involves cutting phenolic resins (from .015 to about .030, some FR4, and some paper-based). These layers will then be laminated into an assembly that will be part of the product.
The parts are fairly small, and can be done on a desktop laser cutter/engraver, but I am getting a little bit of heat damage on the very edges of the cut pieces. I need to determine if this is the price to pay for using a laser, or maybe I neeed to direct the company doing the cutting to modify their cutting procedure a little.
The worst damage appears to be related to the paper based phenolics, and more specifically to the thinner products, however, I have not done enough testing to be absolutely sure if that is consistantly the case.
The damage is similar to a slight heat blistering that some plastics will do, and it appears to affect the lamination within the phenolic sheet.
Is it possible to get a good, undamaged edge when cutting phenolics? Are phenolic laminates compatible with a laser cutter?
I'm wondering if I need to try another laser cutter or possibly a different laser technology to get a better result. It may simply be that I need the cutter to try a different pulse rate or feed rate.
Any suggestions you may have would be appreciated.
---Michael
---Michael
RE: Performance expectations from laser cutting phenolics
A different laser technology may work better- eximer?
Call a few laser manufacturers, check out the trade mags like Laser Focus, Industrial Laser (News?), etc.
There are also some very capable consultants out there.
Jay
Jay Maechtlen
Actually, that's a good point- depending on what result he really needs, a CO2 laser may be "good enough"...
Or, it may not.
Cheers
Jay
Jay Maechtlen
I don't know the gas they are using, so I'll find out. If I can gete a cleaner cut, the CO2 laser will be sufficient for my purposes.
---Michael
