Pre-made assembly for radial arm saw?
I am looking for a pre-made assembly like used on a radial arm saw.
I need a device that can raise and lower a small table 12-18" in a verticle direction. The table would be about 24 inches square, and have a total weight of 150 lbs. I would like it to be operated by a hand crank. The best example I can think of to describe what I want, is the mechanism used on a radial arm saw. I could construct something myself, but I'm trying to avoid reinventing the wheel if something economical is readily available.
RE: Pre-made assembly for radial arm saw?
Do you need the radial capability, or just the up and down? If you just need up and down, and are committed to woodshop technology, take a look at a floor standing drill press.
Googled - - crank raise lower "work table"
Maybe this is more what you are looking for
http://www.factorysupply.net/carts3.htm
They have some mobile lift tables that seem to be close to what you want starting at $268. Try searching part# 2576T71
Barry
