Tension in Timer belts
Hi Freinds,
 In timer belt drives,if we give centre distance exactly,
is it necessary to consider the arrangement for belt tension.
thanx in before
Jhon
RE: Tension in Timer belts
Think about how you will install the timing belt.  Also, what happens if the belt is made a little long, or a little short, or stretches, or thermally expands/contracts.  A loose timing belt will wear faster, and can slip.
I think the answer to this question will vary from belt to belt.  I know that polymide flat belts are often used in fixed center applications using split pulleys for assembly.  Better check with the mfg.
Barry
Hi
Thanx btrueblood & Barry1961
 Can i get details,functioning of  split pulleys
& is that gives preciosin drive like timer belt drive
Jhon
