Flow Through Wire Screen
I'm trying to find information about the relationship between Flow Rate, Area, Velocity, Mesh SIze, Viscosity.
I'm trying to determine what diameter shell I would need (as in a filter vessel) if I desired a certain flow rate of water through a certain mesh size screen, at a certain pressure/temperature.
Any thoughts or directions to references...?
Thanks as always,
CW3
Thanks as always,
CW3
RE: Flow Through Wire Screen
Chapter 8: RESISTANCE TO FLOW THROUGH BARRIERS UNIFORMLY DISTRIBUTED OVER THE CHANNEL CROSS SECTION. (Resistance Coefficients of Grids, Screens, Porous Layer, and Packings)
www.sureflowequipment.com
ww.engfilt.com
ww.spriraxsarco.com/learn
http://www.valveandfilter.com/v-howitworks.htm
http
