heating automotive sheet metal
in need of help:
i am a paintless dent repair technician, with that being said, can anyone tell me whether heating a panel at low temperatures, say 250-300 degrees will change the composition of the panels? i already know it won't harm the paint, but is there any benefit to mee in heating the metal, ie..limbering,or softening the panel?
thankyou for any replies.
ronnie
ronnie
RE: heating automotive sheet metal
I don't know too much about automotive sheet, but I've been looking into this question with low-carbon structural steel plate, and the meaningful temperatures should be roughly the same.
The "softening" is the lowering of the yield strength of the steel. It'll take less force to get the steel moving. The higher the temperature, the lower the yield point, but there is very little effect in the first few hundred degrees. I have in front of me a graph (source unknown) of yield point vs. temperature for various structural steels and at 400F they're showing at best a 10% reduction in yield strength.
There isn't too much effect in the next few hundred degrees either; at 800F that same graph shows at best a 20% reduction. (Which is interesting because I know plenty of fabricators who like to heat things to about 500F thinking it helps things along.) It's after that point that the yield point really starts dropping.
If you're looking to keep the paint intact, I don't think you should bother with the heat. If you do start dealing with higher temperatures, though, stay under 1200F (for low-carbon steel) or you risk embrittling the steel.
Hg
Be careful with Al since it will get much softer, much faster. It would be easy to over do it.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Cory
Are you talking about the "blue brittle" range of steel (about 400-700F)?
Hg
There is no advantage to heating steel panels for this - the elastic and plastic properties do not change enough to help with the dent removal (when keeping the temperature below the degradation limit of the paint).
Cory
as far as time, it was suggested to keep a constant heat on the area of the dent keeping it on during the lenght of repair.
another question is can anyone please guide me to a source explaining how metal reacts under various forces, and how the forming of these auto panels react to these forces of damage as the energy dissapates?
and a final question:i've read that auto panels often have to be stamped twice because of spring back, why does it have this spring back? and why does it have memory?
thanks again,
mendadent
I'd like to try answering that last question, non-metallurgist to non-metallurgist, mostly to see if I can. The metallurgists can clobber me if I've misunderstood it all this time.
As you know, you can bend a piece of metal so far and it'll just spring back to where you started. If you bend it beyond a certain point, it'll move a lot faster, and will stay bent. But that initial amount that would have just sprung back, it's still going to spring back no matter what. So your permanent change is what you moved it to minus that springback piece.
Here's my really simplistic understanding of why there's so far you can move it without permanent change and then after that it does change (here's where the metallurgists may clobber me), and why the springback is still there even after you've set in a permanent bend:
There's a certain amount of "springiness" to the atomic structure of the metal. The atoms can move with respect to each other by a certain amount and still maintain their bonds, like bungee cords. If they're pushed too far, though, those bonds break (the hooks let go) and then reform between new sets of atoms that are now next to each other (the hooks catch the next hole down). That shift is permanent, but the same amount of springiness remains, and the bungee will unstretch by the same amount when you let go.
How far off am I?
Hg
Modulus of Elasticity When a material is subjected to an external load
it becomes distorted or strained. With metals,
provided the loading is not too great, they return
to their original dimensions when the load is
removed, i.e. they are elastic. Within the limits
of elasticity, the ratio of the linear stress to the
linear strain is termed the modulus of elasticity
or more commonly known as Young's Modulus.
Mendadent- The quote you give is the description of modulus, this is the reason for the Springyness. When you begin to permanently deform the metal you have passed out of the linear or elastic portion of the stress strain curve. Now adding force (stress) produces strain (deformation) relatively easily.
"Mendadent- The quote you give is the description of modulus, this is the reason for the Springyness. When you begin to permanently deform the metal you have passed out of the linear or elastic portion of the stress strain curve. Now adding force (stress) produces strain (deformation) relatively easily"
is this what we dent technicians do if we have over worked(pushed) a panel? young's modulas, and is it also the term work hardened? for there are times when we work a dent wrong from the beginning, we stretch instead of shrink and create bigger mess for ourselves, and when it occurs we have spongy but yet lumpy metal, and at best we can only lightly sand at this point and rebuff.
You are asking so many basic questions that we cannot educate you sufficiently. You need to read the book/take the class Metallurgy for the Non-Metallurgist available from ASM International. Go here to learn more:
http
http
Cory
first a question:
have you looked at a stress-strain curve yet?
If not then please do before we go much further.
Ok the Young's Modulus, or elastic modulus, describes the dimesional changes due to application of force in the material. This is only relevant while the material will return to the same shape and form when it is released. This is the straight line that starts at 0,0 on the stress-strain curve. This is also know as the elastic region. Teh slope (rise/run) of this line is the modulus. Once a certain amount of stress (force) has been applied the material begins to take on permanent deformation. This is the part of the curve that is generally not straight. This is known as the plastic region. To make a permanent dent in steel you have to exceed the yeild strength. To remove a permanent dent you also need to exceede the yeild strength.
Over working the material will result in the steel being really strong, but brittle and easily torn.
Nick
I love materials science!
http://ww
Strain is stretch, loosely speaking.
Definitely look at the Metallurgy for the Non-Metallurgist book Cory mentioned. There's an online course on the material covered in the book for "only" $700 if you want to go that far, and a take-home course for $375. Or you could just read the book.
http://
http://ww
Hg
thank you all, this is information i was looking for in original post.
not being a mettalurgist myself, are there none of you that would find my questions from on the job training as challenging, as well as entertaining?
for example: if a door hits another car and puts a crease through a body line, do any of you know where the energy is likely to end up? or what step i would take to start the repair?
thanks to you all in advance, i feel if i can just bounce some questions off engineer's "in the know" i can get a broader understanding as to why what i do in paintless dcent repair works.
With your level of inquisitiveness, though, you might check out some engineering technology classes in your area to see if maybe you indeed have missed your calling.
Hg
but metal is fluid,right? energy does dissapate from point of impact. it causes buckes at times farther from point of impact.
other than this site, do any of you know where or who i can converse with and ask questions?
(Ok well most are, there are some really neat and very new metals that can be cast in an amorphous shape. These have a structure like glass. The max size is really small, and they are really expensive.)
Note that I'm talking about heat straightening, using thermal stresses to induce deformation. Different mechanism than what you use.
Either way, an exact science it ain't, not on any practical level. There's something called finite-element analysis that uses a computer model of the exact shape and deformation of the part in consideration, but it takes so much time to build the model that it's not financially practical (not to mention that the software costs $$$$).
Regarding a forum that's more practically oriented than this one but still with good technical clue...dunno. I know of one for welding, but not metalworking.
Hg
"Sounds kind of like what I see in the girder shops when they go chasing "buckles" out of the larger panels of built-up girders."
that is exactly what it's like. except as you all know in automobile design, most panels have four corners, yet may have several creases,or rounded,or inverted body lines, so we don't have to chase it all over the car. but with the above being said, we do have to find it and every curve, crease,or body line,and even internal glued brace inside the panel, will have an effect on the "buckling" you described above.
if i give you a fax number can i get a copy of that graph hgtx? or is it online?
thanks in advance ronnie
I have been trying to mispronounce your handle all wrong as mendad-ent these past few days while following this thread . It finally came to me (duuhh) to pronounce it mend-a-dent!
You commented above "is this what we dent technicians do if we have over worked(pushed) a panel? young's modulas, and is it also the term work hardened? for there are times when we work a dent wrong from the beginning, we stretch instead of shrink and create bigger mess for ourselves, and when it occurs we have spongy but yet lumpy metal, and at best we can only lightly sand at this point and rebuff."
Not to rebuff Cory's suggestion to educate yourself on the basics rather maybe the followimng will encourage you to persue it: When you have overworked the dent, you have pushed the metal too far past Youngs Modulus (the straight line/elastic portion of the stress strain curve -- yes as someone mentioned, the stress strain curve will indeed help you to understand this.) Once you have pushed it into the plastic region, the metal moves/stretches permanently. No, Youngs Modulus is not work hardening rather work hardening occurs when you stretch the metal beyond the elastic limit so that the next time you work it (next hammer blow), you have to stress it above the increased (work hardened) level that you just induced.
Hg
you see it is easy to pull out tools and start "working a dent" but it is fascinating (whether necessary or not) to understand the intricacies of why what i do works or does not work.
thanks metman
and hgtx, thank you too! i would like to see the graph.
let me propose another question regarding heat: while i now know from all your experiences that heat doesn't change working characteristics unless it is heated very highly; is there merit to say if a quarter size door ding is heated and kept at a constant temperature of 200 degrees, that the 10% it does change,(mentioned by hgtx' graph) ,could possibly be enough to make the heated metal want to escape outward to the cooler metal if being pushed upon?
The strength of the material is not affected by heat however the material will expand causing additional stress to be applied because the heated area will expand and the cold area around the dent will not. It may give the material the additional stress to pop back into the original condition with a little persuasion. The only caveat is that if the material has seen plastic deformation (strain beyond yield point) that material will never return to the orginal shape. This area of plastic deformation may be small enough where it is not visible but I have no experience.
Bill
this may see elementary but if i were to do the opposite and heat the panel around the dent leving the dent cool, are you then suggesting the exact opposite from your quote above? since the metal expands, that it will now be expanding my dent farther inward?
you have answered my question with this statement and i thank you .
"The strength of the material is not affected by heat however the material will expand causing additional stress to be applied because the heated area will expand and the cold area around the dent will not. It may give the material the additional stress to pop back into the original condition with a little persuasion."
A question for mendadent... If I warm my paint to ~150-175C then is there less of a chance of cracks forming when I flex the sheet metal?
What I do:
Mainly Research and Development on specific types springs/hard steel products.
This could involve in any one week:
Rebuilding machines
Writing Code
Wiring sensors
Fatigue testing
Heat Treating
Mechanical Design
FEA/CFD Analysis
DOE
Failure Analysis
Sweeping the Floor
Changing Lightbulbs
Welding
Other various tasks as necessary. <-Directly from my Job Description
Nick
What i have learned is that if you're in the plastic deformation stage(stretched metal) of the stress strain curve,that i not only have to get back to flat, but beyond it to the percentage that had plastic deformation. This alone is what seperates the professionals in our craft from others that just can't do it.I mentioned the last time i made a post here on the site that we have to locate "crowns" i think you refer to them as "metal strain hardens" and beat them down in sometimes many places before we even begin to work the point of impact.
In closing i've come to find there are far too many variables in what causes a dented panel, and even more for how the metal will react after the force is applied due to bracing, body rolls,inverted panels etcetera.
it seems that what we do is magical, because we work this stretched metal back to pre- damage with most times no detection of damage.finally, i leave you with a question wouldn't a measurement of the stress strain curve be a completely different measurement in every conceivable location of an auto body panel over entire car after stamping due to the strength the metal takes on after stamping if the exact impact could be duplicated?
http://ww
Hg
thanks for your resonse and the diagram.
