PropertyBag ?
PropertyBag ?
Hello, I'm writing a VBA program for Autocad 2005. I want to save some property value at the end of the program (like the path of a file or the value of a boolean variable) and be able to retrieve them the next time I'll use the program.
In VB6 I would use a PropertyBag object, but in VBA this object does not appear to exist. For now, I'm saving them in a text file but I dont like it.
Anybody have a better way to save variable value?
thank you
RE: PropertyBag ?
Saves or creates an application entry in the application's entry in the Windows registry.
Syntax
SaveSetting appname, section, key, setting
and
GetSetting(appname, section, key[, default])
RE: PropertyBag ?
It's exactly what I was looking for.
