Pretension in a bolted joint
Hello everybody. I am trying to analyse a bolted joint and i have defined pretension to the bolts. But i see that the pretension section shrinks and the bolt head has negative stresses even though the preload is a tensile load which i didnt understand why. I have defined pretension in step 1 using cload and in the second step i have applied the external load using cload,op=new and i have also used boundary,fixed in the second step. is this right or am i missing somethin? looking forward for your reply. Thanks.
Kota
RE: Pretension in a bolted joint
The bolt head will be in compression generally as it is being loaded by a tensile load acting downwards, and an upward load from the object surface. These two forces apply compression.
corus
and also i had one more question. To check the bolt load i check the contact force since i have defined contact between the upper bolt surface and the upper plate hole and the lower bolt surface and the lower bolt hole. But is this contact force what i get is the force exerted by the slave on the master. 'cause i have defined the bolt as the slave and i am getting the contact force for the upper bolt surface negative( which means the force is acting downards according to the co-ord system i have chosen)..Thanks for ur help. i really appreciate it.
Kota
If you don't believe the results then simply look at the deformed shape of the surface underneath the bolt head. This should show a compressed surface.
Another way of checking the bolt load is to look at the stresses in the bolt shaft. Multiply the average stress by the area.
corus
here are the details:
CFT(BOLT)----1122 LBS
CFT(JOINT)----1122 LBS
EXTERNAL LOAD-- 100 LBS(TENSILE)
AVERAGING METHOD(BOLT SHAFT)--1222 LBS
I always thought in reality the bolt load shld increae and the joint load shld decrease.if i follow the averaging method then it proves my above thought.But if i juss go for the CFT values then both bolt and joint load is decreasing.Do u know why this could be happening? or should i juss go for the averaging method considering the bolt shaft and not the bolt head to get the bolt load and consider the CFT value for the joint load. do u think its reasonable. looking forward for your reply. Thanks.
