replacing diesel with propane
Can propane be used instead of diesel in diesel engine. Any useful links requested
replacing diesel with propanereplacing diesel with propane(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: replacing diesel with propane
But I could be wrong.
Cheers
Greg Locock
Rod
Cheers
Greg Locock
I have to agree about not converting a diesel, as the ignition system of a diesel is compression and proper timed injection and I don't beleive LP could be set up to work this way.
Good luck.
Ed Kay
Ed Kay
Rod
-=Whittey=-
Propane has an octane rating of 104 (depending on its purity, amount of propylene and ethane, and its origination), has a slightly slower flame travel speed than gasoline, a critical compression ratio of about 13:1, and runs at Stoich of 15.5. Its lean and rich limits are 2.1 to 9.6%. Its ideal operating range is around 6.5% (at Stoich). Its combustion flame temperature is around 3500 deg F.
Evelrod is right about using propane as a power booster for trucks, just ask several vendors marketing the kits now, they have never been so busy! But then, so have diesel engine mechanics, as there have been numerous failures. Some dealerships are instructing employees to look for signs of an installed or recently removed propane fumigation system, and if found, the engine warranty is voided! One interesting item I have noted, this problem is regional, and seems to be more pronounced in the midwest and deep south, possibly due to the concentration of diesel ¾ and 1 ton trucks.
Once propane to diesel replacement exceeds about 15%, the combustion pressures exceed the physical limitation of many engines (when combined with diesel) and can cause pistons to destruct, cracked valves and heads, to burned turbo bearings and seals, and warped exhaust manifolds!
Propane as a fumigation fuel with diesel has its place, but in very small minor fractions of less than 10%, and be knock limited, with exhaust thermocouples monitoring temps.
franz
One last thing, the heavier the duty cycle will be (running at 75% of engine rating) the lower the compression ratio should be.
Regards;
Franz
There is information on the web about the engine, but its mostly marketing material.
Franz
