Does anyone know of a Standard documentation method for wire harnessin
I would like to find a free online reference or guide. The specifics that I am looking for are nomenclature -what to name components j1, c3, etc, colors, etc.
Thank you
Thank you
RE: Does anyone know of a Standard documentation method for wire harnessin
There are certainly usefull books available in many public libraries about this stuff.
This may be a little out of place here, but I see you are shown as "(mechanical)", maybe you need an electrician more than a textbook tho. Naming devices and components in a way that's meaningful for those who must build, install, maintain (etc.) electrical systems is something you don't just pick up with an afternoons reading.
If you're up to it, get some copies of some electrical blueprints from a system (building, machine, etc) that is similar to what you're interested in.
best of luck
remember: An opinion is only as good as the one who gives it!
For wire colors check NEMA ICS 1-2000:
http://www
For nomenclature -what to name components check NEMA ICS 19-2002:
h
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
