circular concrete tank-hinged wall base
for a circular concrete tank not prestressed, how do you detail a hinged base between the walls and the base slab? The tank I am dealing with is 40' in diameter and 27' tall. The details that I see in ACI 350.3-01 and "Design of Liquid-Containing Concrete Structures for Earthquake Forces" by PCA seem a little cumbersome.
Instead, I propose that you could provide straight dowells centered in the tank wall between the wall and base slab. The curtains of vertical steel at each wall face would stop at the top of the wall.
All comments are greatly appreciated
RE: circular concrete tank-hinged wall base
Don't forget that there needs to be circumferential or radial bars in the foundation to carry the shear transfer into the base.
