Chapter 22 ACI-02 Plain Structural Conrete
I am working with some Plain Structural Conrete.
Would someone post the nominal Moment capacity formula and Shear formula WITH the correct PHI factors for each formula? Both formulas and PHI factors can be found in Chapter 22 of ACI-318-02 for Structural Plain Conrete.
Could you also please tell me which section(s) each formula and phi factor is from?
Jeff
Jeff
RE: Chapter 22 ACI-02 Plain Structural Conrete
Don't you have a copy of ACI 318? If you are working as a structural engineer, I would think this is a necessary document to own.
Lutfi
www.cdeco.com
