Patran abaqus odb attach error
I am using Patran 2004 to do post-processing.  When I use:
Read results-> result entities -> attach,
and select one of the .odb file from Abaqus explicit, it repeatedly tells the following error:
cannot load dynamic library /local/msc/patran2004/lib/libabaqusdra.so ld.so.:/ ...
I tried to google for answer, but in vain.  Could someone here in this forum lend a hand?  Thanks so much!
