Fanuc 11M Keep Relay Question
I have a horizontal Mori with an Fanuc 11m controller.  When I switch over to the PC side and press the "PCMDI" screen call up to specify a program to run on a particular pallet....  The screen remains blank.  The button is not the problem (it works on all the other screens).  I am assuming this is keep relay setting to make sure the programs doesn't get changed by mistake.
Does anyone know which relay needs to be changed to allow the screen to come up??
Thanks..... Mark
