Isolation Valves at high pressure & high temperature?
Could you, please tell me do you know any company that I can contact it about a 3" Flanged 300# Isolation Ball Valve on Boiler Feed Water line with 400psi and temperature up to 300^F?
Thank you in advance!
RE: Isolation Valves at high pressure & high temperature?
try thomasregister.com
Jamesbury
Mogas
Valve Technologies
Velan
You might have better luck with a local dealer if you're just looking for one off the shelf valve, though.
There are a bunch of other companies out there, but this list will get you started, anyway.
Make sure you specify full port. You may end up with cavitation in some circumstances and you don't want a restriction going through the valve.
